Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Check in error
3 REPLIES 3
sbachar
299 Views, 3 Replies
Check in error
any help with this check in error (attached)?
Very annoying. I checked every part, every drawing, i cannot see what is the problem?
Is there any log file that i can see which files are problematic?
Thanks.
3 REPLIES 3
cbenner
in reply to: sbachar
When you save, do you select "Yes to All"?  It may be that there are files that need to be migrated to the current release of your software. Files that need to be migrated cannot be vaulted and will give an error like this.
sbachar
in reply to: cbenner
I tried this but the error continues. I think this error is not well explained and does not give enough clues about the reason to the error....
Senthil_Kumar
Try using the Filter - Show Modified Files Only-  from Vault browser to isolate the file.
Senthil Kumar
Development Manager,
Be sure to check out the Vault Help!
