Along side my other problems with Vault 2010 I have noticed that in Inventor when an item is checked the "check out" option is still available, not greyed out.
Is this correct or is there something wrong?
Solved by Madhan_T. Go to Solution.
Smidsy,
I would like to try to duplicate this - Is this Inventor 2010 with Vault 2010, or a differnt version of vault? When you see this, are you able to do an undo checkout / check out command / check in command - do any of them generate an error?
This is because one of the children is available for Check Out. The Check Out will not appear if both files are checked out.
Madhan
You are welcome.
This was a request from users to have the ability to check out all the files.
Madhan
