Hi!
I have programmatically changed the category of a file using the method DocumentServiceExtensions.UpdateFileCategories.
Is it possible to force a lificycle change for the new category so that the file is in the default state of the default lificycle assigned to the new category?
Thanks!
Please try posting your question to Autodesk Vault Customization if you have not. You may get better response from that group.
good day,
did you managed to accomplish this?
I want to be able to set my vault to change categories from internal documentation to external documentation ,
so as I reached revision G ( released for production) , can I set up a rule in vault then to change the Category from internal docs to external docs automaticly, and then use revison scheme numerical then instead, and a differint lifecycle?
