Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Change Renaming Scheme for Files ?
5 REPLIES 5
701 Views, 5 Replies
Whenever I attempt to rename files inside Vault it automatically uses an "Update Part Number" numbering scheme whereby it places a prefix "New" in front of every file name. I was wondering how to shut this off or create another default renaming numbering scheme where it does nothing to the file name (so I can just edit it myself without having to remove the prefix "New" from every file manually). It just makes extra work when trying to rename a few files in Vault.
I've attached a picture of what it looks like just in case.
5 REPLIES 5
BLHDrafting
I haven't found a way of permanently turning it off, but by turning the prefix off it goes away. See the graphic.
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
Yeah I figured that out. I was just wondering if there was a way like you said to turn it off completely. Guess not. Thanks though.
Surely there should be an option to turn it off
In any REAL part numbering system, using a prefix of 'new' is ridiculous...
Graeme
It's a pain. There probably is a registry hack somewhere for it but I don't know of any.
There's an Idea Station entry for this feature. Check it our here and vote if you like.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
I see the Ideastation post is "under review." PLEASE implement this, Autodesk!
Andy
Andy Wallace
Autodesk Inventor (2016) (3 years)
previously Solidworks (6 years)
