Vault General
Message 1 of 3 (263 Views)
Change Order Link Properties not working
263 Views, 2 Replies
11-17-2011 12:32 PM
Hi all,
I have a client who is would like to create a Change Order Link Property called 'Priority' that can be set to Low, Medium, or High for each record that is attached to a Change Order.  According to the Wikihelp, that is exactly the type of info Link Properties are used for: http://wikihelp.autodesk.com/Vault/enu/2012/Help/02._Working_with_Vault/01._Vault_Client/1175VaultSe...
However, they do not appear to be working.  Below is the procedure I followed to try to create a Link Property.  I have tried this in Vault Professional 2011 Update 2 and Vault Professional 2012.  Both have the same result.  I have searched the forums, but could not find a solution.  Am I doing something wrong or do Link Properties not work?
1. Open the Vault Professional client and go to Tools->Adminstration->Vault Settings. Click on the Change Order tab and click Properties:
2. Click New to create a new property as shown, then click OK:
3. Close out Vault Settings, then create a new ECO with a record.  The Property appears, but it cannot be changed.
Clicking on the drop-down arrow has no effect:
4. Go back into Vault Settings and check the Link Property.  The settings have been changed:
Kevin Burrows
Technical Specialist
ECAD, Inc.
Message 2 of 3 (210 Views)
Re: Change Order Link Properties not working
02-22-2012 09:34 PM in reply to: KevinBurrows
Thank you posting this messge.
The ECO link Property only works for Items in the Records tab, not for files.
I have log a defect to update the wikihelp message.
Carrie
Active Contributor
Message 3 of 3 (143 Views)
11-27-2012 09:11 AM in reply to: carrie.ruan
I have also since tried to do this with FILES attached to an ECO.  The property appears, but you cannot edit the property.  I now understand (after reading this post) that this can only be accomplished by using ITEMS with an ECO.
I have attached the WIKI Help link that talks about linked ECO properties, but mentions NOTHING about how this can only be done with ITEMS.  This would have saved me a little bit of time if I knew this ahead of time.  Can you please update the WIKI page or put in a request for this to work with files too?  Thank you.
Wiki Help: Manage ECO Properties
You are not logged in.
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
Ask the Community
