Vault General
Message 1 of 6 (820 Views)
Change Autoloader default folder
820 Views, 5 Replies
01-17-2012 12:24 PM
In Autoloader, I want to map to a folder other than "Designs". It's another folder on the same level in Vault.- how can I change this setting? Autoloader always seems to default to "Designs" . The folder I need is not listed at all.
Employee
Senthil-Autodesk
Message 2 of 6 (814 Views)
Re: Change Autoloader default folder
01-17-2012 06:43 PM in reply to: tmccar
Does this help?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9480434&linkID=9261340
Senthil Kumar
Sr QA Analyst
Be sure to check out the Vault Help!
Message 3 of 6 (793 Views)
01-19-2012 10:22 AM in reply to: tmccar
Yes, that's the answer, thanks
New Member
ppsi.engineering
Message 4 of 6 (700 Views)
03-22-2012 01:53 AM in reply to: Senthil-Autodesk
Hi Senthil, thanks for this post, it was a very useful post, along with the other one you made last year regarding changing the default mapping of Content Center Files in Autoloader (http://forums.autodesk.com/t5/Autodesk-Vault/Map-Content-Center-folder-in-Autoloader/td-p/3198942).
I was able to successfully change the mapping of the designs folder, but cant seem to change the mapping of the Content Center Folder. Attached are screenshots showing how the Designs.ipj file mapping in Inventor is to the correct Vault CC folder, but when it gets to Autoloader, it still points to the default CC folder. Also attached are the BUU.xml & Designs.ipj files.
Should I be doing something different?
Inventor 2012 SP1
Vault Colloaboration 2012
Employee
Senthil-Autodesk
Message 5 of 6 (694 Views)
03-22-2012 03:20 AM in reply to: ppsi.engineering
Few changes to be done.
1. Your BUXOM says the Project file is "Drawing.ipj". So this is the Project that you need to change for CC folder Mapping. NOT the Designs.ipj.
2. Do not try to map to a Folder with Name "Library" or "Libraries". Try something Like "CC Folder" and see if you can map.
Hope the above helps.
Senthil Kumar
Sr QA Analyst
New Member
ppsi.engineering
Message 6 of 6 (686 Views)
03-22-2012 08:37 PM in reply to: tmccar
Thanks for the quick reply. It seems that it will only work if you create a new folder when doing the mapping in Inventor. If you try and select any other existing library folder (even if the existing library folder is empty), it will not work.
You are not logged in.
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
Ask the Community
