If you have the SQL databases and the filestores (even though they were backed up seperately), copy them back into the original locations on the server and use the "Attach" command in ADMS Console (first you will attach the KnowledgeVault and then if necessary attach your actual vault).
-Ryan
Thanks Ryan,
We tried this with mixed results. All the files show up in Vault explorer, but many of them cannot be retrieved. It gives a message that says "The file is either missing from the file store or failing validation" I believe that the problem is with files that were checked out when the backup was made. The SQL database can't reconcile where those files are in the filestore.
Chris
The log file shows that it is looking in the correct file store location and that the file exists. See copy/paste from error log. This is only one file of several thousand that shows the same error.
5/5/2014 11:07:47 AM Replicating: Resource checksum failed for 'DR086BAS2.ipt' version 4. Located in the filestore at E:\WPI_Vault\000\000\000\000\000\226\226340\226340_238845_4.ipt.
5/5/2014 11:07:47 AM Could not validate or replicate resource 'DR086BAS2.ipt' version 4. Located in the filestore at E:\WPI_Vault\000\000\000\000\000\226\226340\226340_238845_4.ipt.
5/5/2014 11:07:47 AM *******************************************************************
Error: Soap Exception ( mesg-id = 635348848673089359 )
Exception: OrphanedMetaData [213]
Stacktrace:
