i have problem to searching data,
iin item master have number and item 7SS0601XXXXXXXXXXXX,
but when i do search" 7ss0 " no item to show in this view message,
and i search" 7ss06 " no item to show in this view message,
and i search" 7ss060 " no item to show in this view message,
and i search" 7ss0601 " there are items to show ,
why can't search before, untill i search with word "7ss0601"
Solved by mollons. Go to Solution.
If you append the search string with a * do the search results change?
Also is there a special character after 7ss0601 which cause 7ss601 to be tokenized for the search?
For instance 7ss0601-XXXXXXX? In this case it would search for anythign wiht the a matching 7ss0601 token.
For more information on how search tokenizes serach terms and works in general see this wiki help page:
http://wikihelp.autodesk.com/Vault/enu/Help/Help/0001-Using_Va1/0003-Essentia3/0017-Searchin17
