1) We went into the .iam in INV and in the iproperties/Ocurrence Tab and changed the BOM Structure on one of the components to "Reference".
2) I then "Checked In" the assembly.
3) Next, Updated or Assigned the file in VM2010.
4) By doing this, it gets thru the error 1404.
5) I then go back into the INV and change the component back to "Default" and check it back in.
6) Update the item in VM2010 and jaula...it's fixed.
7) Have had three assemblies so far that it fixes by using this procedure.
Makes no sense....but it has some success.
We quite often get this error on Items assigned to members of iAssy. The only member that don't suffer - the active one.
For that cases <temporary change BOM structure to reference followed by check-in of updated members> method doesn't help.
That same files to the new vault have no problems with assigning item. That means it happen only to modified items.
Any ideas on how to solve this (other than switch to each-and-every member and update item for particular member one at a time which indeed isn't guarantee solution)?
