Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Can't add path to project
4 REPLIES 4
tmccar
1412 Views, 4 Replies
I want to add a folder to my Inventor (Vault) project search path, but if I try to do that it says, "If you proceed, Type will be set to single user". Is there a way to add a path to a Vault type project?
4 REPLIES 4
luttena
in reply to: tmccar
Can you clarify a little bit for me? Are you trying to add a library folder?
Adam
Adam Luttenbacher
Sr User Experience Designer
Autodesk, Inc.
tmccar
in reply to: luttena
Not a library folder, a Workgroup Search Path. When opening files in Inventor, I frequently get the error message that the folder I am searching is not in the search path.
luttena
in reply to: tmccar
Ok. I can confirm that the workgroup search path is not supported for Vault ipj files. The Inventor Workgroup functionality is legacy functionality intended for managing your data on your network and not in the Vault. There is a plethora of data on Inventor projects on the wiki.
 http://wikihelp.autodesk.com/Inventor/enu/2012/Help/2108-CAD_Mana2108/2121-Configur2121/2122-Project...
Adam
Adam Luttenbacher
Autodesk, Inc.
tmccar
OK, thanks for the info
