I want to add a folder to my Inventor (Vault) project search path, but if I try to do that it says, "If you proceed, Type will be set to single user". Is there a way to add a path to a Vault type project?
Can you clarify a little bit for me? Are you trying to add a library folder?
Adam
Not a library folder, a Workgroup Search Path. When opening files in Inventor, I frequently get the error message that the folder I am searching is not in the search path.
Ok. I can confirm that the workgroup search path is not supported for Vault ipj files. The Inventor Workgroup functionality is legacy functionality intended for managing your data on your network and not in the Vault. There is a plethora of data on Inventor projects on the wiki.
Adam
