Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Can't add files to Vault
6 REPLIES 6
claus.forsell
652 Views, 6 Replies
We have upgraded the server to ADMS 2009. Some of the workstations are still running inventor 2008 and on these we got errormessages when trying to add files to the Vault. Checking in files seems working, but looking in Vault explorer the files are still checked out.
We have installed the clientupgrade addin for ADMS2009 on the workstations.
What could be wrong here?
6 REPLIES 6
In our computer, we cannot see any error messages. From your error dialog, maybe it is a server issue. Could you please provide more information such as: does the server work fine? Can other computer connect to the server and add files to vault? Are all files failed to check in? Etc.
We have upgraded to inventor 2009 and now we can check in our files but not without problems. When we check in an idw the check in dialog hangs at 100%. When the "create DWF attachment" checkbox is unchecked everything works fine. We need these DWF documents so this isn't an option for us. Do you have any ideas of what is causing this?
This seems something similar to the issue below:
http://discussion.autodesk.com/adskcsp/thread.jspa?threadID=674585
Shadow
Message was edited by: Shadow Zhou (Autodesk)
Madhan_T
in reply to: claus.forsell
Hi All,
A hot-fix for "Progress bar does not get closed" has been released and it can be found in the following URL
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11643482&linkID=9242019
Thank you for your cooperation and we appreciate your patience.
Madhan
Madhanagopal Thiruvenkatachalam
Principal Engineer
Engineering Escalation Team
Autodesk, Inc.
Thank you, this hot-fix seems to work.
Claus
Madhan_T
You are welcome and thank you for the update.
Madhan
Principal Engineer
Autodesk, Inc.
