The first place I would look is at your project file. In the Inventor
project editor, select the 'Configure Content Center Libraries' button and
make sure your Content Center Libraries are loaded correctly.
You may receive better advice from the users on the Autodesk Inventor
discussion group.
Adam
"shady05" wrote in message news:6266407@discussion.autodesk.com...
hi,
we are using inventor 2009 , Vault 2009 is installed on each workstation ,
all the work stations work with windows XP prof. , ASMS 2009 and content
center only are installed on the server, the server is working with windows
server 2003.
Now we can work with all vault options through inventor an vault explorer.
The problem that we can't access content center from inventor, when we use
place from content center from inventor we get empty library, any solution??
