I have Vault 2013 Basic Client installed. The MS Office Add-in (x32) is also installed. I am using Office 2007 (x32). When I am in Excel or Word, and I click the Log-in on the ribbon, nothing happens. Since I cant login, I can't check-in/out from Excel or word.
As a work around, I have to go to the vault browser and check-in/out from there.
What I have tried so far. Did a repair install on Vault Basic. Followed the hotfix DL20374319. Neither of these fixed the problem.
Why can't I login from excel or word?
Kirk A.
Windows 7 x64 -12 GB Ram
Intel i7-930 @ 3.60ghz
nVidia GTS 250 -1GB (Driver 301.42)
INV Pro R2013, SP1.1
Vault 2013
Kirk,
Do you have this hotfix installed?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20374319&linkID=9261341
-Hywell
Hwyell,
I had trouble in step 1 of the hotfix. The problem was I could not find the folder it was pointing me to. My install folder for the client is c:\Program Files\Autodesk\Vault Basic 2013.
I did check the folder outlined in step 2 and the two files exists there.
