Trying to load Vault Pro on my laptop, and everytime it goes into precheck, it is telling me I need to reboot. I've rebooted, and rebooted, and tried loading SQL 2008 after removing SQL 2005 to see if maybe there was an issue there. I've google a reason for it, and it returned a registy key, but i cleared that key and Vault still requires a reboot.
At this point, i'd love to know either what needs rebooting, or skip the prechecks all together.
here's the log
Verifying that a reboot is not pending. The machine needs to be rebooted before successful installation. Please reboot your machine and then install .
Failure
Checking Operating System Caption=Microsoft(R) Windows(R) XP Professional x64 Edition
CSDVersion=Service Pack 2
OSLanguage=1033
OSProductSuite=256
OSType=18
ProductType=1
ServicePackMajorVersion=2
ServicePackMinorVersion=0
SuiteMask=272
Version=5.2.3790
Successful
Checking for correct version of Internet Explorer Internet Explorer version found on this machine = 8.0.6001.18702
Successful
Checking for a Proxy Server
Successful
Validating Performance Counters
Successful
Checking port 80 for availability
Does not apply.
Validating that IIS Anonymous User Account is set up correctly Anonymous user "IUSR_DONOVANCOX04" found.
Successful
Validating that IIS Anonymous Authentication on IIS is set up correctly
Successful
Validating IIS .Net settings
Successful
Checking for additional IIS ISAPI filters
Successful
Checking IIS directory paths IIS website Default Web Site root directory = c:\inetpub\wwwroot
Successful
Determining IIS website Default Web Site Internet address(es). IIS website Default Web Site server bindings = :80:
Successful
Check IIS connection time out. The IIS connection time out is :900.
Successful
Checking ASP Status Accessing a static file through the http protocol has passed. Test ASPX was able to successfully create a temporary file. ASP Status Check Web Service Call has passed.
Successful
Check permissions of the account used by ASP.NET.
Successful
Checking SQL Server 'DONOVANCOX04\AUTODESKVAULT' The database instance "AUTODESKVAULT" was not found.
Successful
Checking for existing Vaults with a remote FileStore
Does not apply.
Validating that this host name can be resolved on the local network Server hostname as known by DNS = DONOVANCOX04.
Server is resolved to following IP Addresses by the DNS:
192.168.0.14
Successful
Checking for known firewall Setup has detected a firewall is present on this system. Please adjust the settings on your firewall to allow network http access to this computer on port 80.
Warning
Check administrative account creation.
Successful
Exceptions
Title Message
Exception Index (zero based) must be greater than or equal to zero and less than the size of the argument list.
