Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Cad version Higher then Vault Basic. Works?
3 REPLIES 3
CCarreiras
258 Views, 3 Replies
Hi!
It´s possible to work with Autocad 2015 and Vault Basic 2014?
Or, the vault must be always in higher vertions regardind the cad software?
Thanks.
CCarreiras
3 REPLIES 3
DarrenP
in reply to: CCarreiras
you can work with it but you will not get add on in Autocad 2015
you would need to be on Vault 2015 to get the add in for Autocad 2015
DarrenP
CCarreiras
in reply to: DarrenP
Thanks.
So, no addin, but can we check in check out directely from the vault interface to the workfolder, and open the files in acad 2015?
CCarreiras
johannes.bauer
Hi Carlos,
I would recommend upgrading the Vault to 2015.
You should be on the safe side then and the workflow is much smoother and as it is designed.
HTH
Johannes Bauer
Customer Technical Successt
