Hello there,
Recently every time I click on an Autocad drawing icon in Vault Manufacturing 2010 explorer, I get this error as in the attached PDF file.
At the same time a text file (ACDB.err) appears on the desktop and it says: "Unable to load AcDb resource file."
Using XP Pro x64 latest SP. VM2010, AutoCAD & Inventor all as a package.
AutoCAD by itself works fine - can open drawings, edit/and save.
I am totally baffled. Can someone please let me know what is this error all of a sudden?
Mike
Do you see this error specific to any particular drawing or all the AutoCAD drawings? If it is a particular drawing, are you able to open that drawing without any issue in AutoCAD itself?
If possible, could you please share a drawing which has this issue so that we can take a look at it?
No, it happened to all files with .dwg extension.
Regardless, the IT dept. reinstalled Vault Manufacturing, and the issue seems to have gone away.
thanks for replying.
Mike
Thanks for the update and Glad to hear that the issue has gone.
