You need to make sure that the databases and the filestores are backed
up together. Otherwise, you run the risk of integrity problems if they
get out of synch.
That said, it should be possible to use alternative means to handle the
backups. Of course, the Vault Manager backup mechanism takes care of
this for you.
Jeff
Joe Kupfer wrote:
> Are there any know issues with using a Veritas SQL backup agent and backing
> up the filestore and not using the scheduled task command line backup
> method?
> Thanks
> Joe
