Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Autoloader folders invisible
6 REPLIES 6
tmccar
669 Views, 6 Replies
When using Autoloader, at the "map vault folders" stage, I see only "$" and "Designs". Yet when I log in to the Vault client , I see many more folders. Why can't I see the others?
Tags (1)
6 REPLIES 6
Senthil_Kumar
in reply to: tmccar
By default Autoloader always maps to "Designs" folder. That is the reason you see only Designs folder during Map folder stage.
If you want to change it to other folder than Designs please follow the instructions from the following link
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9480434&linkID=9261340
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
tmccar
in reply to: Senthil_Kumar
Thanks Senthil, I will try that
tmccar
Hi - sorry for late reply.  I tried that , but it says "Buu.xml cannot be added due to vaulting rrestrictions - Buu.xml already exists in this project".
  But I don't see the file anywhere except in the root of C:\
Senthil_Kumar
in reply to: tmccar
Looks like you have the BUU.XML already in the Vault. If you show the Hidden files in Vault you can see the BUU.XML at the Vault Root $. If you are sure this was done you and not used anymore you can delete and try again.
Hope that helps!
Senthil Kumar
Autodesk, Inc.
tmccar
Yes, that's it , thanks
cwhetten
FYI, the link above doesn't work anymore.  Use this link instead:
http://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles/...
Cameron Whetten
Inventor 2014
