Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Autoloader failure to create/update Inventor project
6 REPLIES 6
nick
1770 Views, 6 Replies
I'm trying to use Vault 2014 professional Autoloader to load into Vault an inventor drawing, this is to allow my
Templates to reside in Vault.
My vault consists of just a dummy set of data as I am still getting used to the system, it uses a single Inventor project to keep track of the folders.
When going through the Autoloader setup:
I select the folder with my file to upload.
I select the Project to use as my Vault working project.
The file scans OK, and it also has no errors with the duplicates.
Selecting Next button takes my to the vault login screen, here I can log in succesfully.
Then I get the following error:  "Failed to create/update Inventor project file in the vault"
If I log into the vault and view my project file it was been checked out
I have tried everything I can think of to get around this 'Error' issue but so far no joy, does any one have any ideas please?
I can use the autoloader to import none cad related files, i.e. a word document no problem.
Thank you in advance
Tags (2)
6 REPLIES 6
Senthil_Kumar
in reply to: nick
What is the name of the project you have in the Vault Explorer Client? Is it "Designs"? If yes can you please rename that and try?
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
nick
in reply to: Senthil_Kumar
You are correct my project was indeed called "Designs"! I have renamed it and voila! it now appears to work.
Thank you very much for your support
dmorse1
in reply to: nick
I know this issue is several months old, but can you explain how renaming the project file in the vault helps resolve the situation?
I have the same issue as described above.  I will try to rename the vault project file and see if it works, but just want to understand how/why this would work.
Thanks.
___________________________________
Dave Morse, Sr. Technical Specialist
APPLIED SOFTWARE | Harnessing the Power to Go Further | 800.899.2784 | LiveLab Learning
Senthil_Kumar
in reply to: dmorse1
Autoloader also uses the "Designs.ipj" projects. So if the you have that project already in Vault and that is not compatible - this happens if the versions are different - then Autoloader will fail with the following message. That's why renaming the existing one will help in uploading the new one.
Hope this helps.
Senthil Kumar
Autodesk, Inc.
dmorse1
It worked. Thanks for explaining it.
So, should I now delete the renamed project file and use the newly created one(even though it says Edited Out of Turn)?
Thanks Again!
Dave Morse
Technical Advisor
(Sent from my iPhone)
Enceptia
800.454.5499
Direct 210.892.8428
Senthil_Kumar
If that project was not used anywhere you can delete itOtherwise no harm in leaving it.
Senthil Kumar
Autodesk, Inc.
