I am trying to use Autoloader to bulk load Inventor assemblies into Vault Pro 2012.
I have all these assemblies and their parts in a separate folder ready to import. Whenever I open one of these assemblies in Inventor, I don't get any errors; everything is present and correct.
However, when I add these assemblies to Autoloader, I get nothing but errors saying there are issues with children. When I look into this I find that Autoloader is looking for a part in an assembly in a completely different location (which it cannot find) when it actually exists in the same location as the assembly (which works fine when opened in Inventor!!)
The location in question is 'c:\Documents and Settings\{username}\My Documents\Inventor\'.
So to try and overcome this problem, I moved the parts which it claimed not to be able to find from where the assemblies are to the location above. Now you would think Autoloader would be able to find it, but no. Even though the parts are in the location Autoloader looks in, it STILL says it cannot find them.
It looks to me as if Autoloader has some problems.
Has anyone else come accross this?
Sorry. Haven't seen this before. Is there anyway you can share the assembly with me? You can send it to senthilDOTkumarATautodeskDOTcom
Hi
We are seeing this problem also in a New installation of Autodesk Inventor suite 2012. We did not have the problem while using 2009....on our New Workstations running W7-64bit. Workstations have two Disk drives-may be a clue... Note: In the attached PDF the Sub-Assembly was Vault 'cleanly' prior to the parent Assembly attempted to be vaulted. No Files exist in the folder the Autoloader is looking in
Do you have the following files under D:\Designs?
Also are you able to open the Sub Assembly 3-00298-014-01.iam inside Inventor without any problem?
You can also try by removing this sub assembly from Data source before scanning.
If the above doesn't help we might need the entire dataset. You can send it to me at senthiDOTkumarATautodeskDOTcom
Thanks!
To answer your questions. (btw:your email did not work,.....)
Yes all the 37 parts with errors are in D:\designs. They are part of the Sub-assembly (3-00298-014-01.iam) that was Vaulted prior to the attempted Vaulting of the Parent Assembly (3-00298-013-01.iam).
Yes - of the Sub-assembly (3-00298-014-01.iam) open fine without any errors
We are concerned that in do so – we would lose the link between the parent and child. Would the sub-assembly still open when the Parent is opened?
We can do this – But we sent the Pack&Go to our support group (M2 Technologies) and it opened Fine – with Autoloader giving NO errors.
Sorry about the email ID. One letter was missing. Please try again senthilDOTkumarATautodeskDOTcom
So once I get the dataset I should try the following. Please correct me if I am wrong here
0. Place the Dataset in D drive
1. Check-in the Sub Assembly to Vault
2. Try the Main assembly through Autoloader along with the Sub Assembly
