Hi All
Anyone have any sucess in Autoloading Autocad files to Vault, I can autoload them but they never create a dwf visualisation file. Does anyone have a workround as I have 70,000 to autoload.
Thanks in advance
Solved by Senthil_Kumar. Go to Solution.
dsmith, when you executed the upload command in Autoloader, was the DWF set to be created?
Yes it was, if you try it it does not work, The customer only has basic Vault so I cannot use the job server method
You might have done it. But wanted to double check. Did you check the "show Hidden files" option in the Vault Explorer?
Also if possible please send me a sample file for test purpose. You can send it to senthilDOTkumarATautodeskDOTcom
You can try the simplest of drawings from autocad, there is no dwf created or uploaded to Vault. Give it a try and you will see
Thanks for your reply. I can see the issue. DWF creation is failing with the message that Layout is not Initialized. But it is failing even after Initializing the layouts manually.
I am forwarding this to Development.
Thanks for reporting this issue.
A prompt fix for this would be of help as I have 70,000 dwgs to Vault
Dave Smith
Hi Dave,
I am probably tempting fate by updating this thread before anything is released in case there is a problem, but can you re-test after applying ts17763847?
It should be released shortly.
We're having the same problem, any news on the update Richard? What issues does it fix exactly?
Nikos
Any news on when this will be available. I am happy to beta test if it helps
You can get the Hotfix from the following link.
