Vault General
tanveer4m
Message 1 of 7 (1,059 Views)
Autodesk vault 2013 Failed to aquire a license
1059 Views, 6 Replies
09-17-2012 12:24 AM
I install the Vault server & client in my server. Server consol is running fine but for client it is "failed to acquire a license"
Any help
Tanveer
Autocad Draftsman
Employee
Senthil-Autodesk
Message 2 of 7 (1,052 Views)
Re: Autodesk vault 2013 Failed to aquire a license
09-17-2012 01:01 AM in reply to: tanveer4m
Check this solution
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13107015&linkID=9261340
Senthil Kumar
Vault QA Team
Be sure to check out the Vault Help!
tanveer4m
Message 3 of 7 (1,039 Views)
09-17-2012 03:19 AM in reply to: Senthil-Autodesk
I have done all the changes suggested but the problem remain same. no change
Thanks for looking at my state
Tanveer
Autocad Draftsman
cbenner
Message 4 of 7 (1,033 Views)
09-17-2012 06:11 AM in reply to: tanveer4m
Have you restarted the license server?  I have notice, for an as yet unknown reason, that our server will randomly shut down and need to be restarted.  IT is helping me track when this happens to see if we notice a pattern... so far nothing.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
Valued Mentor
Lancasterm
Message 5 of 7 (1,029 Views)
09-17-2012 06:32 AM in reply to: tanveer4m
What type of license server do you have?    Is it configured to be redundant?
Employee
minkd
Message 6 of 7 (1,021 Views)
09-17-2012 08:55 AM in reply to: tanveer4m
Can you look in the vault log (vlog) on the ADMS host for the time period when you got the error?
Also, in the same folder as the vlog there should be a licensingLog.txt file that will have additional information.
With the combination of the two, I might be able to tell why it isn't getting licenses.
-Dave
Dave Mink
Data Management
DarrenP
Message 7 of 7 (1,017 Views)
09-17-2012 09:22 AM in reply to: minkd
did you create a license file for Vault Pro 2013?
You are not logged in.
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
Ask the Community
