OK, thanks. Unfortunately, that doesn't tell me any more than the log
did. Are there any earlier events that might provide some additional
context?
another thing to check for:
Is there a log file in:
%ALLUSERSPROFILE%\application data\autodesk\vaultserver\filestore
(vlog-YYYYMMDD.txt)?
Problems at this stage are usually permissions-related. Can you give me
some details of your environment?
Jeff
siskohfr wrote:
> This is what I found with event viewer:
> 11/04/05 14:23:38
> Produit: Autodesk Data Management Server 4 -- Erreur 29001. Gestion du coffre-fort erreur: Server Application Error
> at CreateVault.CreateVault.Install(IDictionary savedState)
> at System.Configuration.Install.Installer.Install(IDictionary stateSaver)
> at ExecuteDeferredActions(UInt32 hInstall, ActionType actiontype)
> Client found response content type of 'text/html', but expected 'text/xml'.
> The request failed with the error message:
The server has encountered an error while loading an application during the processing of your request. Please refer to the event log for more detail information. Please contact the server administrator for assistance.
> at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
> at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
> at CreateVault.KnowledgeVault.KnowledgeVaultService.DoesKnowledgeVaultMasterExist(String dbUser, String dbPassword)
> at CreateVault.CreateVault.get_KnowledgeVaultMasterExists()
> Pour plus d'informations, consultez le centre Aide et support à l'adresse http://go.microsoft.com/fwlink/events.asp.
