Vault General
Message 1 of 5 (238 Views)
Autodesk Vault Collaboration 2011 File Replication
238 Views, 4 Replies
02-06-2012 01:52 AM
I'm checking the status of the File Replication between two workgroups.
From the Console I see that there are 960 files (~101 MB) unreplicated.
Just to be sure I searched (on both workgroups) for all files with the "File Replicated" property = False.
Found only 2 matches(!!!???).
My question is: where "960 unreplicated files" information come from?
Which is the best way to check if all files have been replicated?
Thank you in Advance
Max
Employee
paul.gunn
Message 2 of 5 (212 Views)
Re: Autodesk Vault Collaboration 2011 File Replication
02-07-2012 07:32 AM in reply to: m.sabotto
Employee
paul.gunn
Message 3 of 5 (211 Views)
02-07-2012 07:33 AM in reply to: m.sabotto
By default a search will only include the 'latest' versions of a file. You might want to retry you search with 'latest' unchecked - this may resolve the discrepency you are seeing.
Paul
MSabottoAdskID
Message 4 of 5 (204 Views)
02-07-2012 08:41 AM in reply to: paul.gunn
HI Paul,
thank you for the feedback, but did not solved the issue.
I still get only few files with the "File Replicated" property set to false, but the console still display 260 unreplicated files.
Do you know where that information camo from? I mean a Stored Procedure or something else?
Max
Employee
paul.gunn
Message 5 of 5 (199 Views)
02-07-2012 10:00 AM in reply to: MSabottoAdskID
Hi Max,
It is puzzling that you are seeing this discrepency. Ultimately both data come from the database - though the search information is served through an index. You could try rebuilding the search index in ADMS console - in case that somehow the search index has gotten out-of-date. Failing that however, I would advise contacting product support with this issue - to my knowledge this is not a known problem.
Paul
You are not logged in.
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
Ask the Community
