Does Vault Basic 2013 have a functionality to intergate with AutoCAD 2013?
By default I have no Vault ribbon in AutoCAD, but it integrates finely with MS Office products. Also I have no information about add-ins in my Vault installation (see attached picture 1).
Additional info:
1) I have tried to add Vault ribbon manually by adding *.cuix file (Adaptation) but it didnt work (see attached picture 2).
2) I have tried to add *.arx files of Vault to applications menu (AutoCAD - Service\Applications), but I`m getting an error while trying to upload two of them (see attached picture 3).
If AutoCAD was installed after the Vault Client, you will need to repair the Vault Client in order to get the add-in
From Control Panel -> Programs and Features, select the Vault 2014 Client
Highlight this and then select Uninstall/Change
Our wizard will start and you can select Add/Remove Features.
The AutoCAD Add-in and any others that are not installed, but eligible for installation should be able to be selected.
-Hywell
Hywell,
there is no Add-ins available to install except MS Office add-in (please see first attached picture - vault_question.png).
This version of client was downloaded from Autodesk subscription center: http://trial.autodesk.com/SWDLDDLM/2013/INVVAU/ESD/Autodesk_Vault_Basic_Client_2013_English_Win_32-6...
Do you have AutoCAD 2013 or AutoCAD LT 2013? Right now the Vault Client Setup does not see any applicable CAD products. For whatever applicable CAD products that it finds it should show them and have the option to install or remove the add-in from that product.
Yes I have AutoCAD 2013 (30-days trial version) and AutoCAD 2012 licensed version. And I dont have any add-ins to install in Vault setup.
