Greetings all,
My company is migrating to Vault and we are nearly complete. Autoloader has generally been an absolute nightmare to work with so I have been able to get almost everything done without using it. However I'm trying to manually update a .DAT menu file in vault for ACADE (Even though Vault does not directly support the ACADE block library, I was able to make it work). Due to vaulting restrictions I cannot manualy update this file as Vault wants to make sure it isn't associated with anything else, understandable.
Here is the issue, I can use autloader to place this file into vault. However I have changed the way Vault handles user names and therefore the original user name and password I put into Autoloader (and checked 'automatically log in next session') is now invalid. When I try to open autoloader I click the 'click here to log out' option and autoloader crashes giving the following error:
Unhandled exception has occured in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately. Signing out of vault failed! ************** Exception Text ************** BulkUpload.BUUException: Signing out of vault failed! at BulkUpload.WelcomeControl.LinkLogout_LinkClicked(Object sender, LinkLabelLinkClickedEventArgs e) at System.Windows.Forms.LinkLabel.OnMouseUp(MouseEventArgs e) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Label.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3634 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll ---------------------------------------- Autoloader Assembly Version: 13.0.47.0 Win32 Version: 13.0.47.0 CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/Data%20Management%20Applications/Autoloader%202009/Inventor%202009/Autoloader.exe ---------------------------------------- Connectivity.Common Assembly Version: 13.0.47.0 Win32 Version: 13.0.47.0 CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/Data%20Management%20Applications/Autoloader%202009/Inventor%202009/Connectivity.Common.DLL ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3634 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3637 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3639 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- DevExpress.Utils.v6.3 Assembly Version: 6.3.1.0 Win32 Version: 6.3.1.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/DevExpress.Utils.v6.3/6.3.1.0__79868b8147b5eae4/DevExpress.Utils.v6.3.dll ---------------------------------------- DevExpress.XtraTreeList.v6.3 Assembly Version: 6.3.1.0 Win32 Version: 6.3.1.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/DevExpress.XtraTreeList.v6.3/6.3.1.0__79868b8147b5eae4/DevExpress.XtraTreeList.v6.3.dll ---------------------------------------- DevExpress.XtraEditors.v6.3 Assembly Version: 6.3.1.0 Win32 Version: 6.3.1.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/DevExpress.XtraEditors.v6.3/6.3.1.0__79868b8147b5eae4/DevExpress.XtraEditors.v6.3.dll ---------------------------------------- DevExpress.Data.v6.3 Assembly Version: 6.3.1.0 Win32 Version: 6.3.1.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/DevExpress.Data.v6.3/6.3.1.0__79868b8147b5eae4/DevExpress.Data.v6.3.dll ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3082 (QFE.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Data Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_64/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll ---------------------------------------- DevExpress.XtraBars.v6.3 Assembly Version: 6.3.1.0 Win32 Version: 6.3.1.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/DevExpress.XtraBars.v6.3/6.3.1.0__79868b8147b5eae4/DevExpress.XtraBars.v6.3.dll ---------------------------------------- DevExpress.XtraGrid.v6.3 Assembly Version: 6.3.1.0 Win32 Version: 6.3.1.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/DevExpress.XtraGrid.v6.3/6.3.1.0__79868b8147b5eae4/DevExpress.XtraGrid.v6.3.dll ---------------------------------------- Interop.Inventor Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/Data%20Management%20Applications/Autoloader%202009/Inventor%202009/Interop.Inventor.DLL ---------------------------------------- Connectivity.Common.Vault Assembly Version: 13.0.47.0 Win32 Version: 13.0.47.0 CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/Data%20Management%20Applications/Autoloader%202009/Inventor%202009/Connectivity.Common.Vault.DLL ---------------------------------------- System.Web.Services Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll ---------------------------------------- Connectivity.Proxies.Security Assembly Version: 13.0.47.0 Win32 Version: 13.0.47.0 CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/Data%20Management%20Applications/Autoloader%202009/Inventor%202009/Connectivity.Proxies.Security.DLL ---------------------------------------- Microsoft.Web.Services3 Assembly Version: 3.0.0.0 Win32 Version: 3.0.5305.0 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.Web.Services3/3.0.0.0__31bf3856ad364e35/Microsoft.Web.Services3.dll ---------------------------------------- Connectivity.Proxies.Utils Assembly Version: 13.0.47.0 Win32 Version: 13.0.47.0 CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/Data%20Management%20Applications/Autoloader%202009/Inventor%202009/Connectivity.Proxies.Utils.DLL ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- lvzuag5_ Assembly Version: 13.0.47.0 Win32 Version: 2.0.50727.3634 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- Connectivity.Proxies.WinAuth Assembly Version: 13.0.47.0 Win32 Version: 13.0.47.0 CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/Data%20Management%20Applications/Autoloader%202009/Inventor%202009/Connectivity.Proxies.WinAuth.DLL ---------------------------------------- Connectivity.Proxies.KnowledgeVault Assembly Version: 13.0.47.0 Win32 Version: 13.0.47.0 CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/Data%20Management%20Applications/Autoloader%202009/Inventor%202009/Connectivity.Proxies.KnowledgeVault.DLL ---------------------------------------- Connectivity.Proxies.Information Assembly Version: 13.0.47.0 Win32 Version: 13.0.47.0 CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/Data%20Management%20Applications/Autoloader%202009/Inventor%202009/Connectivity.Proxies.Information.DLL ---------------------------------------- kfrfrzau Assembly Version: 13.0.47.0 Win32 Version: 2.0.50727.3634 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Web Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3634 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_64/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll ---------------------------------------- uyavl-so Assembly Version: 13.0.47.0 Win32 Version: 2.0.50727.3634 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- uaay3uda Assembly Version: 13.0.47.0 Win32 Version: 2.0.50727.3634 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- 5xpq5uok Assembly Version: 13.0.47.0 Win32 Version: 2.0.50727.3634 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- Connectivity.Proxies.Admin Assembly Version: 13.0.47.0 Win32 Version: 13.0.47.0 CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/Data%20Management%20Applications/Autoloader%202009/Inventor%202009/Connectivity.Proxies.Admin.DLL ---------------------------------------- System.DirectoryServices Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.DirectoryServices/2.0.0.0__b03f5f7f11d50a3a/System.DirectoryServices.dll ---------------------------------------- lcdz8fzo Assembly Version: 13.0.47.0 Win32 Version: 2.0.50727.3634 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- h541yww_ Assembly Version: 13.0.47.0 Win32 Version: 2.0.50727.3634 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- Connectivity.Services.Document Assembly Version: 13.0.47.0 Win32 Version: 13.0.47.0 CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/Data%20Management%20Applications/Autoloader%202009/Inventor%202009/Connectivity.Services.Document.DLL ---------------------------------------- nsessyxq Assembly Version: 13.0.47.0 Win32 Version: 2.0.50727.3634 (GDR.050727-3600) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
So then I tried to trick it by disabling the account in Vault so it would be forced to ask for login credentials. This did work, however when I try to put the new credentials in Autoloader responds with the error: 'Another user is currently using autoloader, please try again later'. So my install of autoloader is useless. I tried to un-install and re-install while also deleting windows registry entries and any files on the C: drive and it still managed to remember the old login credentials. Does anyone know of a way to fix this? It's fairly frustrating
Also, we're running Vault 2009 (autloader 2009) Yes I understand this software is outdated, however it is out of my control.
Ok, I have solved this problem. For anyone else who experiences this, here is what you do;
For some frustrating reason Autoloader crashes under certain log off conditions. If you get this error, you must go into vault and disable the account that autloader is trying to automatically log in with, this will force autoloader to bring up a log in dialog. Once you have 'tricked' Autoloader into working correctly.... you have to delete the BUU.XML from the root drive of your vault. Chances are when Autoloader crashed it left this file locked. Because this file is locked, Vault/Autoloader thinks someone else is trying to use Autoloader and will deny access.
