Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Assigning Categories to files
8 REPLIES 8
Message 1 of 9
BrettCaldeira
731 Views, 8 Replies
In 2010 I was able to easily assign a certain Category to a file, by the files extension. For eample: If I added a *.doc file to vault, it would automatically assign that doucment to the office Category. The same would work for engeneering documents, *.iam; *.ipt; *.dwg would automaticallyt assign to an Engeneering document.
In 2011 there is a default Category, and it doesnt seem to matter what rules you apply for your other categories the default caegory always gets assigned to my doucments.
I cant seem to edit the default categories rules, and if I make another one of my categories default all files automatiically get assigned to that category.
Does this funtionality still work? Am I doing somehing wrong in my setup of the rules?
8 REPLIES 8
Message 2 of 9
luttena
in reply to: BrettCaldeira
Can you please verify that you have the 'Apply rules on file creation' option checked in the Assignment Rules dialog?
Thanks!
Adam
Adam Luttenbacher
Sr User Experience Designer
Autodesk, Inc.
Message 3 of 9
Yes I have it turned on.
Message 4 of 9
luttena
Please remove the * from your rules. I tried the exact same thing and determined that the wildcard is what is throwing off your assignment rule.
Adam
Adam Luttenbacher
Autodesk, Inc.
Message 5 of 9
Thanks Adam
It worked without the wild card. Didnt think of trying that.
Brett Caldeira
Message 6 of 9
Blue94
in reply to: luttena
Hi Adam,
How do you apply rules to my criteria below?
I want to assign the CAT to Engineering if the Created by is ltran or jsmith or mjane. If I added line by line like below, it does not work but I keep just the first line, then it works fine. Can you help, please?
Created by is ltran
Created by is jsmith
And so on
Message 7 of 9
luttena
in reply to: Blue94
The rule condition builder doesn't support 'or' formulas. What I suggest doing is creating multiple file rules instead of 1 rule. For example,
Rule 1: ltran - Engineering
Created by + contains + ltran
Rule 2: jsmith - Engineering
Created by + contains + jsmith
The order of the rules in the list should not matter in this case because the value can only be one or the other.
Let me know if this works for you,
Adam
Adam Luttenbacher
Autodesk, Inc.
Message 8 of 9
Blue94
It works!
Thanks for your help, Adam.
Message 9 of 9
I have a similar situation where I would like to assign a category (AWI Markup) to a file using multiple rules.  I used:
1.  File Name - contains - markup
2.  File Name - contains - awi
I have another category (Assembly Work Instruction) that uses the following rule:
How can I differentiate the rules so these files are categorized separately?
