Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
“An error occurred when applying configuration. See the log for detail.”
2 REPLIES 2
scottmoyse
610 Views, 2 Replies
Check out this post to help you fix up this error message:
http://designandmotion.net/autodesk/vault-export-config-adms-error/
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
2 REPLIES 2
Dear Scott,
Thinks for your posting 🙂
From log file, I notcie that the log shows there are duplicate rule name. Please check all the rules and make sure there are no duplicate rule names.
Please let me know if the solution not works.
Rohn
scottmoyse
in reply to: scottmoyse
Umm cheers for replying. I think you may have misunderstood, I stated the solution you have above in my blog post, you are correct it does work, however it is a bug which will need fixing at some point. Thanks again for taking the time to reply.
Scott Moyse
