I keep a folder in my Vault project of drawings received from outside contractors. The idea is to just add them to the Vault without modifying them in any way for record keeping. In previous versions of Vault (2008) it was easy to do this. I would simply choose "Add Files..." and I would be prompted with:
"You are attempting to add one or more drawing files. Files will be added but dependent relationships will be lost. To retain relationships, add using the CAD program. Do you want to continue?"
Then I would choose "Yes" and everything would be cool.
I am now attempting the same thing in 2010 and I get the following message:
"Files cannot be added due to vaulting restrictions."
along with the sub-message that reads
"You must add design files to the vault through the appropriate application to maintain correct relationship data."
I don't want to open these files in AutoCAD. From there I would need to save them and that would be altering the data that I received from the contractor. Any ideas?
-Mike Parsons
Edited by: Mike1491 on Nov 13, 2009 2:02 AM
