Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
ADMS login credentials changed
1 REPLY 1
DeconSmal
300 Views, 1 Reply
I just added a new user this past week and need to reindex the server console. It seems as though the login credentials have inadvertenly changed as odd as it seems. They have never been manually changed from the default login. So at this point I am unable to login to ADMS. Is there any way to reset the credentials back to the default settings?
Please help!!
Best regards,
DeconSmal
1 REPLY 1
olearya
in reply to: DeconSmal
Hi There,
Can you check you are entering the correct administrator password (If running a scheduled backup from the command line you may actually have a record of the current password), failing this you will likely have to contact support.
We obviously do not provide a simple way to reset you administrator password as this would represent a pretty significant security flaw.
Allan
Product Manager
Autodesk, Inc.
