Hi all,
I know that Windows 8 is not officialy supported by ADMS Pro 2014 (... .NET 4.5????)
I've recently read on "Design & Motion" that it will install albeit with a warning.
Well, is there a way to install it under 8 Pro and which is this warning?
I need it only in a testing environment.
Thanks a lot.
i tried to install on windows 8 i couldn't get it to
DarrenP
Well... I've got it!
You have to add ASP.NET 4.5 functionality to IIS:
It works for me.
I want to emphasize, however, that Windows 8 is not officially supported so do not use in a production environment.
i will try this
DarrenP
it didn't work for me
oh well
DarrenP
thats fine
i'm not really worried about it at the moment
DarrenP
@Anonymous wrote:
Well... I will post all the steps later. Everything seems to be working so far: win 8 pro 64 + vault pro 2014 + sql 2012 express ...
Messaggio inviato tramite smartphone.
If you post the steps here later, then I can link through to it from the D&M post if you like?
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Well, here's a step-by-step procedure that works for me.
Well... I hope I wrote it all down because in reality this is the result of several attempts and google searches. The problems were, however, all related to the precheck of ASP.NET.
I don't know if it can be interesting but on the PC I had already installed Visual Studio Express 2012 (Desktop and Windows 8 editions) prior of everything.
I don't post snapshot because they're in italian.
I hope it was helpful.
Ok I updated the D&M post with a link back to this solution.
Cheers for sharing it. It's awesome when people post back to their original question with their own solution.
http://designandmotion.net/autodesk/autodesk-vault-2014-insight-whats/
Scott Moyse
