Installed Vault, ADMS, and Inventor 2008 about a year ago. Have had practically no issues with the Vault/ADMS side of the installation until yesterday morning. I, and a fellow coworker, have spent considerable time researching this problem and thus far have been unable to correct this problem.
-Came in yesterday morning Vault was not working. Asked IT to bounce the server.
-IT checked server didnt see anything wrong, so they rebooted it. Ever since then we have been unsuccessful in getting the ADMS console to run.
I have loged into the server containing ADMS as a user and admin (usually I logon as a user account and then run as an admin).
It then gives me a msg I had never seen before.
"Impersonation User Login... ASP.NET impersonation... Logon Failure: unknown user name or bad password"
I have tried every user installed on the machine, verified their credentials and it still gives me this error upon attempting to run ADMS.
If I put my credentials in again, at this prompt, and hit retry it then asks for the SQL System Administrator Login. This login is familiar, but no matter what I put in here it does not accept it. I've verified all the sql services are running (except for the server active directory helper which will not start), I have tried the information on:
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=7333531&linkID=9261340
related to "\AutodeskVault " with no success.
I am not up on todays IT things (I use to work on computers and networks around when Win95 came out), but I need to get this back up ASAP and my IT person is only available over the phone today (he's already given it a good shot at fixing it yesterday).
Can someone please suggest a fix? It is perplexing since everything has been fine for so long. As far as we know there have been no changes to the server. I realize this has to be incorrect as something changed. I did change my personal password (I realized I hadn't in a long time) around the same time, but I don't think ADMS was using my credentials for anything.
please help.
Chris
