Just installed Vault 2014 and we are already having issues. This happens every afternoon for no apparent reason. How do you fix this...???
Do you have SP1 installed for Vault?
Is it only certian times of the day when you get this error?
Have you tried changing the connection timeout value?
Are you able to go through the Windows logs using the Windows Event Viewer where the Vault Server is installed to see if there are any errors returning there? Also, are there any other web applications that are using the same IIS port as Vault Server?
Samuel
