I now get an 29001 error when installing 2013 vault server dealing with Microsoft..csharp. Have been searching for solution, so far, no joy. Hopefully can get one from the group. TIA
Hi There,
This usually relates to a security / rights issue as the dialog suggests (access denied) - is there any further information in the install log?
You can ensure that you have full admin privledges, check the install source files, check the install path, install each of the supporting components seperately to get a more detailed error message etc.
There are a number of artcicles relating to 29001 errors on cracking the Vault: http://crackingthevault.typepad.com/.services/blog/6a01156eaaf373970c01156eaaf391970c/search?filter....
However these do not seem to exactly relate to your issue - I would look to create a support case if you are still not able to install.
Logged in as administrator, full privleges.
Install gets to the languages part and then gives the error and stops.
There is more from the error log if it will help.
Partial log:
[FileLoadException: Could not load file or assembly 'Microsoft.CSharp, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. Access is denied.]
System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks) +0
System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection, Boolean suppressSecurityChecks) +567
System.Reflection.RuntimeAssembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) +192
System.Reflection.Assembly.Load(String assemblyString) +35
System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +123
[ConfigurationErrorsException: Could not load file or assembly 'Microsoft.CSharp, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. Access is denied.]
System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +11560720
System.Web.Configuration.AssemblyInfo.get_AssemblyInternal() +192
System.Web.Compilation.BuildManager.GetReferencedAssemblies(CompilationSection compConfig) +337
System.Web.Compilation.BuildManager.CallPreStartInitMethods() +280
System.Web.Hosting.HostingEnvironment.Initialize(ApplicationManager appManager, IApplicationHost appHost, IConfigMapPathFactory configMapPathFactory, HostingEnvironmentParameters hostingParameters, PolicyLevel policyLevel, Exception appDomainCreationException) +1167
[HttpException (0x80004005): Could not load file or assembly 'Microsoft.CSharp, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. Access is denied.]
System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +11693424
System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +141
System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +4867301
</pre></code>
