To clarify, the option to install the server was removed from the Inventor
installation wizard in the 2010 release. However, the disc is included in
the Inventor case. Simply put the disc in and you can choose to install the
ADMS and Content Center.
The option to install the Vault Client is still included in the Inventor
installation wizard.
Adam
"TommyQian-Autodesk" wrote in message
news:6281868@discussion.autodesk.com...
Hi AlexS,
Vault server is located in Inventor disc. When you install Inventor, you
will find the Vault Server option in the Inventor installation wizard.
Hope this helps.
Tommy
