Trying to created more hard drive space on a workstation.
What is the best way to delete local copies of a many vaulted files.
They are saved in many different locations. Is there a way to quickly delete all local copies from a machine with just a couple of clicks?
Using Inventor & Vault 10
I tried this app months ago and it didnt work with Vault Basic.
I contacted the developer and below is their response. Seems like the problem is Autodesk. It would be a very welcomed feature to have available.
Vault Basic 2013 is not customizable, so it is not possible to provide an app that works on this platform.
Delete Local Copy is available for Vault Workgroup 2013 , Vault Collaboration 2013 , Vault Collaboration AEC 2013 and Vault Professional 2013 as you can read in the "Compatible with" section of the app page: http://apps.exchange.autodesk.com/VLTC/Detail/Index?id=appstore.exchange.autodesk.com%3adeletelocalc...
I hope to have answered to your question and I also hope that in future release Autodesk will support Vault Basic customization.
I use the same vault, when right mouse button on the folder or file in de vault, you can choose for goto workfolder.
Then in explorer you can just delete the files from that folder.
Also possible is to check the second box in the checkin window on closing the files, the local files wil be removed..
