Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
vault error value canot be null
4 REPLIES 4
jacoj
676 Views, 4 Replies
please help !!! cant access vault file, only folders is vissible, if I change the view settings, you can see imnage, and try to open I get the attached error. 2013 PDSS trail ran out, and we installed 2014 PDSS trial while we waited for 2013 LIC . we are now back on 2013 PDSS installed and licenced, but, vault is giveing this error, any idea how to fix this, without formatting, its a huge issue to get an older version LIC
4 REPLIES 4
Senthil_Kumar
in reply to: jacoj
This is due to .Net 4.5 which is installed from 2014 release. We have fixed this issue in Vault 2013 SP1. You can download and install it from the following link.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21017345&linkID=9261341
If possible please go ahead and install the latest Update 2 for SP1 from this
http://usa.autodesk.com/adsk/servlet/ps/dl/index?linkID=9261341&id=2334435&siteID=123112#section2
Hope that helps.
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
jacoj
in reply to: Senthil_Kumar
Thank you
Will do this,
But do I need to manually remove the .NET 4.5?
Kind Regards
Jaco Jansen van Rensburg
Drawing Office Administrator
ELB ENGINEERING SERVICES
ELB ENGINEERING SERVICES AFRICA
Direct: +27 (0) 11 772 1433
Cell: +27 (0) 83 321 0544
Fax: +27 (0) 11 325 6680
Web: www.elb.co.za
ENGINEERED SOLUTIONS for LONG TERM RELATIONSHIPS
Confidentiality Caution: This email and all its contents are subject to the ELB disclaimer
Senthil_Kumar
in reply to: jacoj
No. You do not need to remove .Net 4.5. Installing SP1 will fix the issue.
Senthil Kumar
Autodesk, Inc.
jacoj
thank you This seems to fix the problem but seem the drag and drop capability is not working now because of the .NET 4.5 instead of 4.0 but at least the user is up and running again thank you
