Hi all
I have got the ribbon panel showing in autocad for vault but it is blank.
I added the tool bar but when I click it the command line does not recognise the system variables for vault.
Solved by samuel.seah. Go to Solution.
Can you do a reinstall of the Vault Client from the Windows Program and Features and see if it works for you?
Samuel
Please try the command "cuiload" to unload the Vault Add-In and then load the Vault Add-In again using the VaAc.cuix customization file.
Samuel
Are you able to post a screenshot of what you are seeing?
Samuel
Thanks for the screenshot. Some questions:
Samuel
I have autocad michanical on my system but do not use it. I just opend it up and vault is fine on that.
I believe that the AutoCAD Add-In is either uninstalled or removed by non-standard means from the system. Please try to remove the AutoCAD Add-In from Add/Remove Features by unchecking the option. And then repeat the process to get the AutoCAD Add-In back by checking the option.
Samuel
