Hi all you experts 🙂
does anybody know how to define the search Conditions in the vault reports.
I use the System File Properties Table Report as test, and only wan't to search for files with the extention dwg?
how do i do this. no matter what i try it to type into the search template it does not work.
please help.
Regards Kent boettger
Solved by wayne.brill. Go to Solution.
Hi Kent,
I am not an expert on RDLC and Vault reports but I did find a way to make the Hidden Visibility expression on the on TableRow True or False depending on the extension. The "File Table.rdlc file has this function. (I opened it in Notepad)
<Code>Function GetExtension(st1 As String) If st1.Contains(".") Then Return (UCase(Right(st1, Len(st1) - InStrRev(st1, ".")))) End If
Return "" End Function</Code>
I used this function in the expression for the Table Row:
=IIf(Code.GetExtension(Fields!ClientFileName.Value) <>
"DWG", True, False)
In my tests only the dwg files are listed when I run the report. I attached a screenshot to help explain.
This page has a description of using an expression to hide a row:
http://msdn.microsoft.com/en-us/library/dd354976.aspx
Wayne
