"Vault Basic 2013 could not find the Data Management Services on localhost" is exactly how the error reads.
Win7
AIP2013 Update 1.1
Thanks in advance for any assistance
Is localhost the name of the server where the Vault ADMS is? I think what you need to do is, on the initial login, type the name of YOUR server where it says "localhost". Then select the correct Vault from that server. (ther emay be more than one if you have a test environment or kept the out of the box Vault).
Checking the "automatically log in" next time will save your setup and a lot of time. See screen shot:
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
