Hi there,
I have an inconsistent behavior with Vault Collaboration 2013. I want to restrict the release process. I should only be able to release designs when depedent child files are released. The checkbox "Check that dependent child files are released" in the Transition dialog box is selected. In addition, the files that I'm testing are under he same category. Finally, the Lifecycle definition that I'm using only has ONE Realeased State under the Control tab in the Lifecycle details section.
Is there anything else that I can check in order to restrict the release workflow?
Vault worked before but now it's inconsistent.
It would be helpful if you could provide more information.
What type of issue are you seeing?
Can you give some screen shots of the assembly structure?
One common problem we see is that people change the state (and therefore the revision) of the referencing file (the "parent") and the referenced file (the "child") separately. This is not wrong. However, many don't realize that when this happens the referencing file is still consuming the previous revision of the referenced file. This can give unexpected results, because the previous revision and the tip revision can have different released status.
Currently the only way to get the referencing file to consume the new revision is to check it out and check it in from the CAD system (or task manager) with the desired revision of the referenced file on disk.
Hope this helps.
Mikel, thanks for your reply.
I hadn't replied back because Vault Pro 2014 will be installed and we will see if the problem is still there after having migrated.
I'll get back to you if the problem persists.
I'm having the same problem.
I'm working with Vault PRO 2016 and even with the check box "Check that dependent child files are "Released"" on the transition Working in Progress --> Released, I still can change the state of an assembly with Its dependent (child) in Work in Progress.....
I did the same test using the State "Obsolete" and that works fine..... I can't understand why this only happen on the Release state.
I also double check if the check box "This is a "Released" state" was checked - It is.
