Hi, I have a problem with printing files directly from the Vault pro. Visualization files are up to date, when sending files to print appears an error (printsceen). Is the change of state files from "production" to "to review" is necessary?
What version of Vault are you using? Also, is it Basic, Workgroup or Professional? Where are you printing from, and what is your exact workflow? You should be able to print a visualization in any state.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I agree with Chris that there should be no restriction on printing versus the file state.
There are known issues when using Vault Plot combined with the option to use visualisation files. I have 2 acknowledgements from Autodesk support about problems when printing using the DWF file. Until these are fixed I have changed the option to NOT use DWF files. It takes a bit longer to print and uses a few more resources but it works.
I am using Vault Professional 2014. Attempt to print a DWF file results in an error. When I try to print a file IDW is not send it for printing. it takes a very long process but does not send the file to the printer. Sometimes, the file is sent to print but prints an empty card. Next file is still only processed. Vault is divided into two positions, the second position is only possible to print DWF files that are exempt from production.
This sounds a lot like what Brendan is seeing (previous post). I have avoided the 2014 upgrade, I see too many issues raised in these forums. Next year I'll have no choice, so I hope that 2015 is a better release.
Chris Benner
I really can't think of a reason why you're having issues. My next move would be through my VAR and/or raise a case with Autodesk.
I'm not sure what this section of your message means but it could hold a clue "Vault is divided into two positions, the second position is only possible to print DWF files that are exempt from production." Can you detail this more please?
I solved my problem. In the name of the folder were Polish characters (ą, ć, ś, ń). For this reason, the path to the file got lost.
