Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
iParts not working with Vault Basic 2014 add-in loaded
4 REPLIES 4
karthur1
386 Views, 4 Replies
Using Vault project with Inventor. Opened Inventor assembly that uses an ipart.  Changed member to a member to a member that was not yet created.
After 15minutes, Inventor is still trying to save the member. Used WIn Task Manager to end task.
Restarted Inventor, using same ipj, I went to Tools>Add-in and unloaded the Vault add-in.  Opened same assembly and changed to the new memeber as before.  Now Inventor saved the new member.
Why does this hang with the Vault Add-in loaded?
(Ref iSST Boards.ipt)
4 REPLIES 4
Senthil_Kumar
in reply to: karthur1
Hi Kirk,
Could you please send me the iPart file? You can send it to me at senthilDOTkumarATautodeskDOTcom
Thanks!
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
karthur1
in reply to: Senthil_Kumar
Senthil,
I have these products installed:
Inventor Pro 2013
Vault Basic 2013
Vault Basic 2014
ADMS 2014
Before I installed Vault Basic 2014 (server and client), I uninstalled Vault Basic 2013 (server and client).  I was testing if Vault Basic 2014 was compatible with Inventor 2013. Turned out that it was not, so I reinstalled Vault Basic 2013.
In Inventor when I unload the Vault add-in, I now realize this is probably the Vault 2013 and not the 2014 add-in... correct?
I am working on another issue with Vault Basic 2013 and I need to install SP1 for Vault Basic 2013.  Hopefully that will solve this issue as well. It will be later this afternoon when I get back in front of the computer to install the SP1.
Senthil_Kumar
Hi Kirk,
Thanks for your reply. Vault Client 2014 will not install add-in for Inventor 2013.
If you have the following setup
Inventor Pro 2013
Vault Basic 2013
Vault Basic 2014
ADMS 2014
then, Inventor Pro 2013 with 2013 add-in should be able to log into ADMS 2014.
Senthil Kumar
Autodesk, Inc.
karthur1
Senthil,
I installed Vault Basic 2013- SP1 and its working correctly now.
