Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
firewall and license
4 REPLIES 4
wesbird
556 Views, 4 Replies
  I'm evaluating the Vault right now, please forgive me if I ask question already answered. I tried google first already.
  When we install Vault, it will run behind company’s firewall, is it possible to access it out of firewall (work from home), even further behind another firewall (from client site)?
  Another one is about license, if I login, checkout drawing or whatever, then I logout, can I still working with the drawing in AutoCAD. I try to save some license if possible.
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
4 REPLIES 4
DarrenP
in reply to: wesbird
for this you would have to setup some sort of VPN connection
once you log out of vault the vault license should be returned
DarrenP
m.mees
in reply to: DarrenP
You can continue working on that drawing as normaly a local copy of that drawing is generated when downloading it from Vault.
Regards.
Marco
r.smith1
in reply to: m.mees
Hi Marco,
Yes, if the file is checked out from Vault and copied to a working folder that is accessible to the machine that has it checked out, the file will be available for modification until it is checked back in.
Ron Smith
New Product Introduction Manager
Autodesk, Inc.
DarrenP
in reply to: r.smith1
yes you could do that
but i am assuming they would like to check in/out of vault outside of the firewall
DarrenP
