Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
feed excel metadata to vault file properties
4 REPLIES 4
tanveer4m
1386 Views, 4 Replies
I was using Bentley Project wise & now wanted to migrate from Bentley to Autodesk vault. I have 30 to 40 thousand files in out project wise data base & indexed. I can generate .cvs metadata file for our project-wise database . but how to import that data at once in vault? do I need to upload the files & fill the attributes manually?
Any help/suggestion please.
Tanveer
Autocad Draftsman
4 REPLIES 4
xavier_dumont1
in reply to: tanveer4m
What kind of file do you have (Autocad or Inventor)? Does those metadata are linked with iProperties in Inventor or block in Autocad?
tanveer4m
i have already configured autocad attribute  files in vault but for non attribute files are more in number beside that pdf tiff & some other documents are there i have collected their all attributes in our old data base. now i need to put that meta data into vault. scanned tiff files are aroud 17,000 in number. but i have thier attribute in excell sheet.
Tanveer
Autocad Draftsman
xavier_dumont1
Ok, Autodesk Vault has an API who can give you tools to upload those kind of metadata. The best is to ask your reseller about that.
Maybe a tools like CoolOrange DataLoader can do this kind of Job: http://www.coolorange.com/en/products/dataloader
tanveer4m
in reply to: xavier_dumont1
http://www.youtube.com/watch?v=NxdjdpfCzW8
I have seen in above linked vedio clip He is inserting the files into vault & feeding attributes from excell. I tried to do same way he is doing but my vault folder structures are different than him.
"importfileproperties -s localhost -db vault -u adminstrator -p "" import.csv" this is the way he is using in vedio clip but i cannot find any such files in my vault anywhere in my PC.
Any help please.
Tanveer
Autocad Draftsman
