Is there any way I can add a watermark to the visualization attachments which are pubished to the webviewer? I have seen this option for Items but we currently don't use Items in Vault.
You can add Watermark when you use Batch Plot.
http://wikihelp.autodesk.com/Vault/enu/Help/Help/0001-Using_Va1/0030-Batch_Pl30
Thanks for your reply. I am aware that I can add a watermark when using the plot function from Vault, however, that is not what I am trying to achieve.
I would like to add a watermark to the visualization attachement based on lifecycle state so that the watermark will be visible to any user who logs into the webclient to view files.
Did you achieve what you were trying to do. Because even i am trying to add watermark. Can you provide sample pseudo code
I'm looking for the same thing, so has there being anything new with this?
As far as I know up through 2013, Lifecycle watermarks could only be placed on Items. I haven't had the chance to dig into 2014 yet, but I thought I saw something about some enhancement to watermarks. I have no idea what that means though until I get inside and poke around.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Product Management is already looking into this Idea/wishlist. You can see that from the following links
http://forums.autodesk.com/t5/Autodesk-Vault-IdeaStation/Marking-in-Preview-based-on-Lifecycle-State...
http://forums.autodesk.com/t5/Autodesk-Vault-IdeaStation/Water-Marks-for-DWFs-in-Vault-WG-Collab/idc...
Please go ahead and place your votes using Kudos for these ideas.
