Any idea????
Error when the 4th incremental backup was doing.
Executing Vault Maintenance
14/04/2011 21:30:27 ==================================================================
14/04/2011 21:30:27 Logging initiated: Core server version 14.2.71.0
14/04/2011 21:30:27
14/04/2011 21:30:27 -Obackup -B"F:\taga\Backup\Vault" -VU[username] -VP[password] -S -DBSC -INCR-L"F:\taga\Backup\Scripts\VaultBackup.log"
14/04/2011 21:30:30 ==================================================================
14/04/2011 21:30:30 INCREMENTAL BACKUP PROGRESS: The server console is currently in the process of backing up a database set. Please wait...
14/04/2011 21:50:01 Backing Up Databases... 0/5
14/04/2011 21:56:48 Vacuum Cleaner: Deleted D:\FILESTORES\TAVIL\000\000\000\000\001\207\1207436\1207436_1207437_1.dwf
14/04/2011 21:56:48 Vacuum Cleaner: Deleted D:\FILESTORES\TAVIL\000\000\000\000\001\207\1207438\1207438_1207439_1.ipt
14/04/2011 21:56:48 Backing Up Databases... 1/5
14/04/2011 21:56:48 Backing Up Databases... 2/5
14/04/2011 21:57:19 *******************************************************************
Warning: Failed to rollback transient permissions
Exception: F:\taga\Backup\Vault\VaultBackup_2011_04_14_09_30_31_Inc04
14/04/2011 21:57:19 Connectivity.Application.VaultManager.ServiceException: Write on "F:\taga\Backup\Vault\VaultBackup_2011_04_14_09_30_31_Inc04\databases\TAVIL_dbbak" failed: 112(Espacio en disco insuficiente.)
BACKUP DATABASE is terminating abnormally.
10 percent processed. ---> System.Data.SqlClient.SqlException: Write on "F:\taga\Backup\Vault\VaultBackup_2011_04_14_09_30_31_Inc04\databases\TAVIL_dbbak" failed: 112(Espacio en disco insuficiente.)
en Connectivity.Core.Database.TransactionContext.OnSqlException(SqlException e)
en Connectivity.Core.Database.SqlAccess.e(SqlCommand A_0)
en Connectivity.Core.Database.SqlAccess.ExecuteNonQuery(CommandType commandType, String commandText, Int32 commandTimeout, SqlParameter[] commandParameters)
en Connectivity.Core.DataAccess.KnowledgeMasters.BackupDB(String dbName, String backuppath)
en Connectivity.Core.Operations.Backup.a(DirectoryInfo A_0, String A_1)
en Connectivity.Core.Operations.Backup.a(DirectoryInfo A_0, KnowledgeVault A_1, Replicator A_2)
en Connectivity.Core.Operations.Backup.a(DirectoryInfo A_0, DirectoryInfo A_1, KnowledgeVault A_2, SiteAuthenticator A_3)
en Connectivity.Core.Operations.Backup.a(DirectoryInfo A_0, DirectoryInfo A_1, BackupContents A_2)
en Connectivity.Core.Operations.Backup.Execute()
en Connectivity.Core.Services.KnowledgeMasterService.Backup(String backupPath, BackupOptions backupoptions, ICollection`1 excludedLibraries, OnProgressDelegate onProgress)
en System.Runtime.Remoting.Messaging.Message.Dispatch(Object target, Boolean fExecuteInContext)
en System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext)
--- Fin del seguimiento de la pila de la excepción interna ---
en Connectivity.Application.VaultManager.ProgressCommand.Execute()
en Connectivity.Application.VaultManager.BURWizardDataModel.a(TypeFullOrInc A_0, String A_1, String& A_2, List`1 A_3)
Finished With VaultBackup.cmd
21:57
Regards
Solved by paul.gunn. Go to Solution.
The pertinent error here is 'Espacio en disco insuficiente' when trying to create the backup file on drive F.
Insufficent disk space ?
Paul
