If I right mouse click on a AutoCAD drawing in the assoicated file list of an item and select "View In Window", vault issues a Operation failed: System Error. Please Contact Your System Adminstrator. This only happens on "DWG" files.
View in window works fine everywhere else and the preview/view tab shows the dwg with no problem. When you select "view in window" in the assoicated file list, DWG Trueview appears to be used (per a test on another vault pro 2013 system) whereas the other "view in window" options, design review is used. DWG Trueview opens fine on its own. This happens on numerous PCs. I have also reviewed the server logs but did not see anything in there either..
Any ideas?
Vault Pro 2013 UPDATE 1 (server and clients)
Hi Lancasterm,
Please uninstall DWGTrueView on one system, and reinstall it from the 2013 installation media. Does the issue go away or does it remain?
