We have 15 seats of Inventor. Will I run into the 10 maximum connections with Vault 2013 if I install it on a Win7 PC? Should I be using Windows server 2008 instead?
Solved by DarrenP. Go to Solution.
yes you will hit the 10 connection limit unless that has changed with windows 7
i will have to look
DarrenP
i found it: http://windows.microsoft.com/en-US/windows/answers?tId=6f4fa572-db2e-4446-a263-52cf32b6b518
its 20
DarrenP
